Problem with onedrive
jonathan.sadin
Post by jonathan.sadin »
Sorry for my bad english.
I Want to sync large files to onedrive (8 GB mkv file), but I got error : Erreur: Echec lors de la copie de Source : HTTP/1.1 416 Requested Range Not Satisfiable
Is there a max size ? 4 Gb ?
Or is a bug transfer ?
I have no probleme with more little size file.
I got office 365 and have 1Tb stockage on onedrive
Re: Problem with onedrive
Post by Kostas »
You may need to generate a Support Zip with debug log for your profile and send it over to us for investigation.
Conrad Chung
Post by Conrad Chung »
That error code:
may be caused by situations when the client sends a fragment request that overlaps with an existing fragment that has already been received.
When you transmit a file to/from a Cloud service, it sends it in fragments. As each fragment (or range) gets written successfully, the cloud service will ask for the next range/fragment to copy from. In some situations, a client may sent a fragment that the server had already received, and since OneDrive does not support uploading bytes that have been previously uploaded, it will respond with a HTTP 416 Requested Range Not Satisfiable error.
This may be due to glitches when writing large files and the range in which to copy next may be mis-communicated between cloud and client.
Can you re-try and upload the file again to see if you continue to get the same error? If the error persists, please follow the instructions as posted by Kostas to generate the Support Zip with debug log and send it over to us.
Engztrom
Experienced
Experienced
Post by Engztrom »
Got the same error for 3 random files on my ongoing backup to OneDrive, which I started yesterday.
But if it is a Microsoft issue it will never get fixed on their side...
So as a workaround, couldn't SyncBackPro just retry sending the whole file again when this happens?
My log:
Profile Name: D to OneDrive - media (ej filmer, dokumentärer)
Source: D:\Media
Destination: \D\Media
Cloud: Destination is on the cloud.
Compression: Each file on Destination is compressed
Unattended: Yes
Trigger: Manual
2017-05-06 08:37:12
\Bilder\2013\130608\till pierre\2 - On my way home, (part of trip, when approaching Överstbyträsket from Rörån).mpg
Error: Failed to copy from Source : HTTP/1.1 416 Requested Range Not Satisfiable
2017-05-06 10:57:39
\Bilder\2014\140630\MOV03005.MPG
2017-05-06 16:18:11
\Bilder\2014\141115 - 141116\00000.MTS
