Feature request for bandwidth control
keithl
Post by keithl »
I love this product. Syncback Pro product has enabled me to get ride of several other products that were backing up my various data to different cloud providers./ The only thing I wish it had was the ability to adjust the cloud bandwidth and have it take effect on the running job. It seems when I make changes to the bandwidth setting I have to stop the job and run it again to have the change implemented. Aldo with multiple backup jobs running I would like to have a second setting that would say have a global bandwidth number then each profile would have a percentage of bandwidth setting. When multiple profiles are running they would each get the designated percentage of the global bandwidth number, but and if only 1 profile were running then it would get 100% of the global number. Maybe every 60 seconds it can evaluate the conditions and adjust for multiple profiles as needed.
Re: Feature request for bandwidth control
Thank you for your suggestion. I will pass this on to our Development team for their review and consideration. As our To-do-list is a long list, we can’t guarantee when these features will be implemented. I will keep you posted once we have further information.
lagvoid
Post by lagvoid »
I would like to second this request. Syncback has been the best program to accomplish my backup goals after testing MANY. However, this is the one feature it is lacking. I have to pause the backup because it will basically hog the entire bandwidth for my computer. I have tried using 3rd party bandwidth limiters and controls, but they don't work since the actual upload is being treated as a Windows process and not through Syncback.
Thank you for your great software!
Impossible
Post by Impossible »
This feature would be of great benefit to my configuration.
pdwalker
Post by pdwalker »
For what it is worth, another vote for the rate limiting feature so I can prevent a backup job from hogging all the network bandwidth.
spalan
Post by spalan »
I agree, this would be helpful. =D>
