How to enforce programs to run with admin rights with a profile
hithere
Post by hithere »
How to launch batch files with admin rights, defined to run before/after performing a Syncback task?
SyncBack itself is running with admin rights.
Background: I want to unlock a bitlocker protected backup drive and lock it after performing the backup with a batchfiles:
Unlock bitlocked drive batch file contents:
Code: Select all
manage-bde -unlock g: -rp 0123456-0123456-138952-233849
Lock bitlocked drive:
Code: Select all
manage-bde -lock g:
Those commands when launched manually with elevetad rightts but don't work if launched by SyncBack profile.
Re: How to enforce programs to run with admin rights with a profile
Hi, the problem isn't related to any lack of elevation (assuming Pro is run that way, which it is by default, and as you obviously expect that, I assume it still is).
If you use the Test button in Programs-Before, you should get a 'file not found' error (that's the clue). The problem is that the manage-bde program you are asking Pro to call lives in \System32\ folder and because of this syndrome, Windows is redirecting Pro's call from \system32\ to \SysWOW64\ instead (where manage-bde doesn't exist - thus, the 'not found' error).
If you use the \sysnative\ path alias mentioned in the KB article, e.g.
Code: Select all
C:\windows\sysnative\manage-bde -unlock g: -rp 0123456-0123456-138952-233849
(likewise for the lock command), you should find it works. I just tried it & both commands work fine for me, but fail if I don't use the path alias.
hithere
Post by hithere »
Cliffhanger, I can see a huge amount of awesomeness in your postings. Thanks a lot. That helped!
rizrashdi
Post by rizrashdi »
Actually I have a follow up if I may. I'm running into the same symptom. I run a simple batch file which compresses a PST file before doing the actual backup.
Code: Select all
C:\Users\xxxxx\Desktop\xxx\Email\rar a -ep -rr10%% "C:\Users\xxxxx\Desktop\xxx\Email\SDGE Archive 2016.rar"
When I manually run the batch file from windows explorer it runs fine. However when I run it using the "TEST" button through syncbackpro i get the below access denied message highlighted in yellow (I added a pause statement to see the message).
10-20-2016 2-48-40 PM.png (5.23 KiB) Viewed 6659 times
Syncback tells me the return code was 0 so it thinks all is well and dandy. This is on a work laptop so I do have to run things with a separate administrator login at times when I need elevated privileges. This used to work fine but I'm sure sometime along the way they pushed some new policy onto these laptops and since then I get this error. But the fact that I can double click run the file makes me think clicking the "Test" button in syncback should be ran under my same credentials. Right?....
Syncback is installed under "C:\Program Files\2BrightSparks\SyncBackPro\SyncBackPro.exe". Running SyncBackPro v7.6.8 on win7 32bit. If it helps any I use WinRAR and it uses "C:\Users\xxxxx\Desktop\xxx\Ftp\Temp" as the folder for temporary files.
Please submit a support zip with debug logs for the profile in-question by using the Contact Support links in this article and attach the support zip file for further investigation.
