Syncronized Backup w/ SFTP Problem
Jukari2003
Post by Jukari2003 »
I've been using SyncBack for years without any problem... however today I went to Sync my data with my Synology NAS and I got the attached errors with all 12465 files in that profile:
First it looked like a permissions issue, so I checked the permissions of the account and it has full access over the directory structure. Then I tested the permissions in both Windows Explorer and FileZilla with no problems, I can create both folders and files using Explorer and FileZilla using the same FTP account. But, SyncBack doesn't seem to work for some reason using the exact same credentials. Not to mention most of the files it says "need to be copied, are actually already on my NAS". When I test the connection SyncBack can connect successfully.
- I tried creating an new profile and it's doing the exact same thing under a different profile.
- I'm using the latest and greatest version of SyncBack Pro 7.6.4.0 (Registered & Paid for)
The FTP account works fine with all my other SFTP Sync Profiles in my Profile groups I have set for other directories, but not that specific directory structure.
Any ideas?
Re: Syncronized Backup w/ SFTP Problem
Post by Kostas »
I would suggest submitting a support ticket for your failing profile by using the Contact Support in the below link in this article and attach the zip file.
Scott Leff
Post by Scott Leff »
I'm having a similar problem and I'm wondering if you ever got this resolved.
I'm able to connect to the remote SFTP server using FileZilla as well as Free File Sync. I'm transferring files with no problems. SB Pro was working for me up until 2 days ago, and suddenly stopped connecting.
Scott Leff wrote:I'm having a similar problem and I'm wondering if you ever got this resolved.
Please submit a support ticket by using the Contact Support in the below link in this article and attach the zip file.
