Delete Destination files prior to backup job
kon
Post by kon »
Hi guys,
Very new to Syncback Pro. Running version 7.6.8.0.
Searched through forumns and couldnt find my answer.
I would like to set up a simple job that backups files from a Source, files from source that are only 7 days old and do a complete delete of files on Destination prior to backup job starting.
Are you able to help me with this?
Thanks in advance.
kon
Post by kon »
Hello all,
Very new to SyncBackPro. Running v7.6.8.0.
Would like some help with what I think should be an easy solution.
I have a job set up as Type Mirror.
I basically want to copy files from Source to Destination.
Source has files that are over a month old. I only want to copy files that are 7 days old.
Destination, I only want to store that last backup. So I would like to do a delete prior to the backup job starting.
Thats it.
I hope you can help, and would greatly appreciate it.
Re: Delete Destination files prior to backup job
Modify profile -> Expert -> Copy/Delete -> Advanced -> 'Delete ALL the files.....in Destination before...'
Be very careful to choose the correct side (there is a similar setting that will wipe your Source if you select it, and then run the profile...)
For the age-limit aspect, see this post. Check out the comments in the Help (press F1 with Date & Time settings page open) about 'averaged values' and how rounding-down is used. You may wish to consider using a cutoff setting of '168 hours' or '10080 minutes', etc. (rather than '7 days')
kon
Post by kon »
Hi cliffhanger,
Thank you so much for the response.
Have tried it out and has worked perfect for me.
