Multiple Profiles same source/destination?
Cain
Post by Cain »
Can I have multiple profiles backing up from the same source to the same destination???
I have one folder that I'd like to FAST Backup maybe only once per week (D:\ServerFolders\Archive). I might have other ideas for different subfolders at different intervals.
My source will always be: D:\Server Folders But perhaps different subfolders with different frequencies and settings.
I'd like to always back everything up to the same folder on my NAS in a remote location via FTP.
Thanks!!
Re: Multiple Profiles same source/destination?
Yes, it is possible to create multiple profiles with same Source & Destination root paths. You can simply create one profile and make multiple copies of it from SyncBackPro’s main-interface (select the profile > right click and choose ‘Copy’ from pop-up menu > give a different name to the newly created profile). And then change the file/folder selections for each profile under:
Modify > Simple > Choose sub-directories and files settings page.
Cain
Post by Cain »
Perfect, thank you!
