Restore from Backup with Versions
djsep3763
Post by djsep3763 »
I client of mine was recently infected by the Cryptolocker virus on June 20th which resulted in me having to restore from backups. They are running a backup job using SyncBack Pro V7.6.8.0 with versioning set up for 7 versions and no limits to a NAS. Before restoring from backups, I first moved the infected files/folders in to a folder I named "Crypto Infected". I then created a folder with the same name as the orignal "MB7" and performed a restore using the rollback feature to the folder I just created. I did a rollback to the last known good backups which occurred on June 19th, the day before the infection. The restore was successful. It restored everything and then some. There were old files and folders in there that weren't from the original folder structure, including files/folders that were deleted long ago. The rollback option I had chosen was "Rollback all destination files". I was under the impression that performing a rollback restore to a specific date would result in the original file/folder structure before the infection occurred. What went wrong?
Thanks in advance.
Re: Restore from Backup with Versions
Please note that "Rollback all your Destination files" will rollback only the destination files. But, if you want to rollback both Source and Destination files then you have to select the option "Rollback all your Source files". Please read this KB article for the detailed steps to rollback your Source/Destination files:
http://support.2brightsparks.com/knowle ... sion-files
Maybe, there are versioned files stored in the $SBV$ folder corresponding to those old/deleted files. Thus, the rollback operation has restored those old files/folders from the versioned files present in $SBV$ folder.
