SyncBackPro V7.6.18.0 released
Post by mickyj »
SyncBackPro V7.6.18.0 (7th July 2016) is now available for download:
Digitally signed by 2BrightSparks Pte Ltd
Changes made in this version
Fixed: Visual issues related to high DPI
Fixed (Pro): Drag and drop of scripts onto main window
Fixed (Pro): Fixed issues with some MIME types on Google Drive
Changes made in V7.6.14.0
New: Romanian translation by Cătălin Truţă
New: Korean translation by Jongun Ha
Updated (SE/Pro): SyncBack Touch option for very slow connections
Updated (Pro): Supports multipart upload with hicloud (S3 compatible)
Updated: Cleaned up start menu on older versions of Windows so URL links no longer listed
Updated: Installer no longer gives option to visit Twitter page
Updated: Link to 2BrightSparks Facebook page from Help menu
Updated: Improved performance when a directory cannot be scanned
Fixed: Profiles getting variables from actual parent when manually run as part of a group within a group
Fixed (SE/Pro): When using multi-zip compression and versioning on FTP or Touch then may fail to delete some old versions
Fixed (Pro): When Google Docs files downloaded they are exported in Microsoft format, if possible
hhdopy
Re: SyncBackPro V7.6.18.0 released
Post by hhdopy »
For my case it worse than before (all was fine before) !
Windows 8.1 64-bit home
DUAL-DVI ([email protected])
Lcd screen : QQnix QX2710LED
see joined image
Thanks in advance
Post by mickyj »
Hi, thanks, we already have a fix for this and will release a new version soon. This isn't related to high DPI.
hhdopy
Post by hhdopy »
ok. Thanks
