Synch between two external drives
Atrebates
Post by Atrebates »
I have always previously synched between an internal (desktop) drive, and external USB backups.
The new scenario: using a smaller computer (e.g., Intel NUC) without large internal memory, but an external USB drive for primary storage.
And then using other external USB drives for safety backup/synch.
Question:
Can I use SynchBack to synchronize between the 'primary' external drive, and the 'back up' external USB drives, if they are all 'external'?
Re: Synch between two external drives
Post by Kostas »
SyncBack should have no problem accessing drives, internal or USB for this matter, as long as they are properly identified by the Windows operating system and have been assigned a drive letter.
Atrebates
Post by Atrebates »
Apologies for taking so long to get back.
Good to hear it should work.
I assumed it would be okay, but was a bit uncertain.
Also...back in XP days I remember trying to pass data from one external drive to another 'through' my PC, and it was very slow. No doubt a USB issue.
I'm sure all has improved.
Thank you for the reply.
