Suddenly 1 folder gets errors during sync
ameagari79
Post by ameagari79 »
I have Windows 10, syncback pro version 7.6.8.0
I have a drive on my pc and an external Passport drive. I keep all my media files synced-- pictures, music, books.
Everything has worked great until recently when one very particular folder suddenly won't sync. The folder is within other folders. It's pictures.
Here's a screenshot of some of the errors.
http://imgur.com/7nlj07u
This worked fine up until not long ago. I have been ignoring the errors but decided I better deal with it. Oldest log I have is July 6 but it started before that.
Any idea what could be wrong? All the other folders sync fine. This one is within the same profile. That is, I sync it's parent folder and the parent folder as well as all its sister folders sync properly. Just this one won't. I haven't made any changes that I know of except to change it from read only just a few minutes ago, since I thought maybe that was the problem. Then I realizeed the folders that sync properly are also read only.
If possible, explain it like I am 5? This stuff is not easy to me.
Re: Suddenly 1 folder gets errors during sync
The reason for getting the error message "The file could not be checked for changes" is explained in this KB article:
http://support.2brightsparks.com/knowle ... or-changes
which states that “The folder is both on the source/left and destination/right but only the contents of one of them could be scanned”. Because of this, the files in those folders cannot be compared – hence they are skipped. Maybe the user running SyncBackPro does not have permissions to read/access that particular folder or something else is stopping it from being scanned?
In addition, please note that your version of SyncBackPro is outdated. You can download and install the latest version from the link below:
After upgrading, please retry the profile run. If the issue persists, send us the Support Zip with debug logs for investigation. Submit a support ticket by using the Contact Support link in this article:
If your Zip is over 30MB, contact us for alternate instructions. Do not post (nor links to) Support Zips on this open forum.
