Can't enable settings encryption
im_thatoneguy
Knowledgeable
Knowledgeable
Post by im_thatoneguy »
When I attempt to enable settings encryption I point it to a 256-bit AES key that I generated with the "create key file" button. But it gives me an error:
"The settings could not be saved: Decryption failure on setting SN: Key file required to decrypt"
im_thatoneguy
Knowledgeable
Knowledgeable
Re: Can't enable settings encryption
Similarly is there a way to lock the settings in a profile with a password? We're trying to ensure that a user couldn't simply change a profile to delete all of our backups by changing a profile from a backup profile into a delete-previous-versions profile or even and then ransomware our working data if they gained access to the backup account somehow.
Post by Kostas »
About the key error "The settings could not be saved: Decryption failure on setting SN: Key file required to decrypt", this usually indicates that SyncBack cannot locate or access the current key file used for encryption. Something may have placed a lock on the key file or it may have been deleted before the new key file has been created. Can you tell us the exact steps to recreate the issue? Also which folder did you choose for the new key file?
As for your question about profile password protection, there is already an option inside the profile under Expert -> Misc -> "Password protect this profile from modification or deletion" which does what you want.
im_thatoneguy
Knowledgeable
Knowledgeable
Well, I don't want to be too specific in where I was trying to save to over a public forum, but it was on a local RAID for a file server inside of a permission protected general IT files folder. However I'm logged in as an administrator that has access to that folder.
It also gave me an SMTP key error the first time. But now it gives me the SN: Key error alone.
Post by Kostas »
I suggest submitting a support ticket for your case by email to [email protected] as it will make it easier to follow up.
