SyncBackPro BETA V7.6.27.0
Post by mickyj »
A new BETA of SyncBackPro is available for download:
It contains the following changes:
New: In file and folder selection window can now open selected folder in File Explorer via pop-up menu
New: In file and folder selection window there are new main menu options to ignore or include all new files and folders
Fixed: Visual issues related to high DPI
Fixed: Search in profile configuration
Fixed: GROUPNAME and VISUALGROUPNAME variables were not set to an empty string if not run as part of a group
Fixed: CRITICALERROR variable now set in Run After
Fixed: The File and Folder Selection tree was not using the display filters
Fixed (Pro): Drag and drop of scripts onto main window
Fixed (Pro): Fixed issues with some MIME types on Google Drive
Updated: The main menu option to only show groups and profiles not in group is now enabled by default
Updated (Pro): Safe copy filename will only use original filename extension when using Google Drive
Updated (Pro): Immediately aborts when with Google Storage on upload when user wants to abort
