Save and compress
pat4446
Save and compress
Post by pat4446 »
Hi and sorry for my english #-o
I wand save and compress daily a folder in a zip file including the date to keep several instances
Is it possible?
Pat
Re: Save and compress
This is possible by enabling single zip compression option and adding a variable %DATE% in your Profile's Destination path.
You can enable single zip compression under:
Modify > Expert > Compression settings page > tick the options "Compress the files on destination/right into a Zip file" and "Put all the files into a single compressed file"
Please read the help file for more details about these options. With Compression settings page opened, press F1 to open the contextual help.
Then add %DATE% variable to your Destination path to backup files to a new zip file each day.
For example: You can set your Destination path as D:\MyBackup\Backup%DATE%.zip. When the profile is run SyncBackPro will create a new zip file with the current date ("D:\MyBackup\Backup4-10-2016.zip") on your Destination and backup files to that zip file.
Please refer to this forum post for more details:
http://www.2brightsparks.com/bb/viewtopic.php?t=3705
pat4446
Post by pat4446 »
Hi
Thank you very much.
Very clear explanation even for me!
Pat
