How to sync ONLY folders, or files with specific size?
pickone
Post by pickone »
Hi!
I want to make a sync profile which is syncing only the folders, or only the files with zero size. So... On the left i will have a partition full of folders/files (games, movies, etc)... and in the right i want to have syncronized only the folders (or only the zero files size, because i thing it will work for folders too).. This is possible?
Thank you in advance!
pickone
Re: How to sync ONLY folders, or files with specific size?
Post by pickone »
I managed how to do it
Closed
