FTP constantly disconnecting, eventually fails (aborts)
Tyree
Knowledgeable
Knowledgeable
Post by Tyree »
I just set up an ftp server (filezilla) at my brother's house in order to do an offsite backup. I can connect to send test files with an ftp client and with SyncBack, but when I actually run a full profile, SyncBack can't stay connected long enough to do its full scan of the remote data. It scans a few files, disconnects, reconnects, scans a few more, disconnects...until finally it aborts saying it could not reconnect. I have it set to Fast Backup, but it can never get past the first scan to be able to use the Fast Backup on subsequent runs.
I increases the Reconnect Attempts and Read Timeout to see if that will give it enough tries to be able to finish.
Does anyone have any insight as to what I might try to get this working?
As another avenue I might pursue if the ftp won't work, can SyncBack automatically connect to a VPN?
Thanks!
Matt
Re: FTP constantly disconnecting, eventually fails (aborts)
Please submit a support zip with debug logs for the profile in-question by using the Contact Support links in this article and attach the support zip file for further investigation.
