Reset Last Run Result?
Tyree
Knowledgeable
Knowledgeable
Post by Tyree »
This is more of an OCD aesthetic thing than a real problem.
I have a group profile that just houses test or unused profiles to keep things neat. I did a test run on one of them and aborted it, now I have the big, red, "Simulation Aborted" text in the Result column. I like to look at my SyncBack screen and see a column of green and no red! :-D
Is there a way to reset the results on that group so it's just blank?
Thanks!
Re: Reset Last Run Result?
http://www.2brightsparks.com/bb/viewtop ... 16&t=12470
(Note: if you look below - at Similar Topics - you might see the same topic liste)
PS: if you mean set the Results of all the profiles in that Group to [blank], that's not currently possible. That other topic suggests it might be soon. Meantime all you can do is clear the Result for the Group and collapse it. (Or, run the profiles again so that they succeed; bear in mind that you can tell a Simulation to Continue (rather than Abort) without changing any files.)
Tyree
Knowledgeable
Knowledgeable
Post by Tyree »
Yeah, my apologies, I saw the other topic at the bottom after I posted this.
What I ended up doing was copying each of the profiles and then deleting the aborted ones, then renaming the new ones back to the original names.
Thanks!
