Network connection works with Test button but not when running job
simonmason
Post by simonmason »
I have a Synology NAS that I backup a lot of my files to. I have jobs in Syncback Pro that accomplish this. Many times the job fails and is unable to connect to the NAS. I have put all of the network credentials into the Network login screen.
On the occasions that the job fails, if I go into modify network and click the Test button I get the Success pop-up. Then if I run the job it works fine.
I am confused - if Syncback is able to test the connection through the modify screen, why isn't it able to connect to the NAS when running the job?
Re: Network connection works with Test button but not when running job
If the issue occur again, please submit a support zip with debug logs for the profile in-question by using the Contact Support links in this article and attach the support zip file for further investigation:
