SyncBackPro V7.6.45.0 (8th November 2016) released
Post by mickyj »
SyncBackPro V7.6.45.0 (8th November 2016) is now available for download:
Digitally signed by 2BrightSparks Pte Ltd
Changes made in this version
Updated: Windows XP is no longer officially supported
Updated: When using screen reader the auto-collapse option in profile config window is not enabled
Updated: Warning text in profile config window now a tab stop to help with screen readers
Updated: New pop-up menu and shortcut keys to select source (Ctrl-F2) and destination (Ctrl-F3) versions from Differences window
Fixed: On Vista and newer, if profile was set to run on logout, shutdown or restart, and it was Windows shutdown aborted, then SyncBack did not close properly
Fixed: French help file may not display
Fixed: The attributes and dates are now from the target file when compressing symbolic link files
Fixed (Pro): In rare cases the download of large files from S3 and Azure may be corrupt
sorabji
Re: SyncBackPro V7.6.45.0 (8th November 2016) released
Post by sorabji »
Is anybody else getting this message from Norton 360?
Threat name: WS.Reputation.1
Norton will not let me download this file. Nothing wrong with it, right?
Post by Kostas »
We are absolutely certain that our software contains no viruses, malware or trojans, and we take any false positive results very seriously.
Unfortunately the latest security update from Symantec is in error and has identified our program as a false positive.
Please visit our NoNasties page for further info:
http://www.2brightsparks.com/nonasties.html
We have informed Symantec of the problem and I am positive that Symantec will resolve the error in due time. They should release an update containing a patch to correct this issue soon. Once they do, please update your antivirus signature files.
You could also contact them to complain direct as an 'affected user', which may help.
sorabji
Post by sorabji »
Much appreciated.
