I had some folders that wouldn't delete when I ran a profile. Assuming Syncback must have a good reason, since the developer has a long history of smart decisions, I went digging. I discovered hidden files in the folders. Then I found this in the SB profile:
Perfect !!! That fixed it! Just what I needed.if a folder cannot be deleted because it's not empty, and it just contains the following files, then delete them to make it empty:
I love how it's obvious that Syncback has been around a long time and been maintained by a very talented developer.
I really wish you had a Mac version. I've been using SB Pro daily for 10 or 15 years. Mickey is a star in the world of software. My biggest gap on my Mac is backup software. I've tried a dozen or so file sync apps for the Mac. All pale in comparison to Syncback! I run a Windows VM just to back up my Mac files. Carbon Copy Cloner (Mac-only) is way better than any Windows imaging software, but CCC just does the Mac's image. I also want to backup my Mac's files separately, and Syncback is the best file backup/sync around, on any platform.
Still hoping for a Mac version one day.
Thanks Mikey, you're awesome.
