Is there a way to write that on the Subject of the email? It will be a dream to manage the filters that way.
Write [Success] on successful logs?
Re: Write [Success] on successful logs?
You can add the variable %RUNRESULT% in the Subject under:
Modify > Expert > Log > Email Log settings page
to show a textual description of the result of the profile run (e.g. Success, Failure, Aborted, Timelimit Reached) in the subject of the email notification.
Please read the help file > Technical references > Variables for more details.
Perfect thank you, it works wonderfully. Sorry one more simple question, I'm not much of a coder even for really simple things like this one, how can I make it work inside []? It only works if the parentheses don't touch the %%. Thanks.
Sorry, my bad, it works perfectly even as [%RUNRESULT%].
Thank you again.
Thank you again.
