I'm using the latest version of Syncbackpro and I can only seem to split zip file into smaller archives if I'm using one large zip file for the entire backup. Is it possible to split zips from default compression mode where each file gets zipped separately? This would help when uploading to Amazon Drive since it seems to have issues with large files that are around 30GB. But I still want to remain on default mode with separate zips.
Thanks!
Split each zip file into parts?
Re: Split each zip file into parts?
Sorry, the option "Create a multi-part Zip file..." is only available when using single zip compression, but this feature is not supported with multi-zip compression.
