Utility to switch on/off the USB backup drive
daandi
Post by daandi »
For our backups I use an external USB drive. The drive is permanently connected to the computer. I'm looking for a way to protect against ransomware that encrypts all files that it can find on a machine.
I'm looking for a utility where I can activate the USB drive before starting the backup and deactivate it after the backup.
Is there a utility that can ‘switch’ on and off an USB drive (optimal with password protection) that can be started out of Syncback?
Best regards
Andreas
Re: Utility to switch on/off the USB backup drive
There is no inherent feature in SyncBackPro to activate or deactivate a drive before and after the profile run. However, you can try embedding commands to do this under:
Modify Profile > Expert > Programs-Before/After section
either directly or by calling a batch file or script file. Sorry, but we don't provide bespoke support on what those specific commands should be or write/debug custom scripts/batch files as this is beyond the scope of our support.
I would suggest you to read these articles which provide suggestions on how to protect your important data from ransomware or cryptolocker:
http://www.2brightsparks.com/resources/ ... mware.html
daandi
Post by daandi »
Thank you for your answer and the links.
I was thinking of embedding a command, but where asking if there is a command or utility known to use. No scripting, only a hint to a command. Would this be possible.
There is no function or command available in SyncBack to lock/unlock an external drive. You have to use a HD protection software to do this and if that software allows you to lock/unlock the drive using command line calls, then you can embed those commands in SyncBackPro's > Programs-Before/After section to unlock/lock the drive during the profile run. Sorry, but we can't provide any recommendations for 3rd party programs as it is beyond the scope of our support.
