Difference between these two options?
ozgurerdogan
Knowledgeable
Knowledgeable
Post by ozgurerdogan »
Difference between these two options? 2nd option keeps file in a sub folder called $SVB$ whereas 1st keeps on its original place?
Decisions - Files:
Delete file from destination if it hasn't been modified within the last x days : 30 Days
Versioning:
Keep versions for a maximum of x days : 30 Days
ozgurerdogan
Knowledgeable
Knowledgeable
Re: Difference between these two options?
ozgurerdogan wrote:Difference between these two options? 2nd option keeps file in a sub folder called $SVB$ whereas 1st keeps on its original place?
Decisions - Files:
Versioning:
The option “Delete a file from destination if it hasn't been modified within the last 30 Days” deletes a destination only file if its last modification date/time stamps are older than 30 days, and the option “Keep versions for a maximum of 30 Days” tells SyncBackPro to delete a version file from the hidden $SBV$ folder (that is created before updating, deleting or moving a destination file), if its versioned date & time is older than 30 days.
Note that when SyncBackPro creates a version file it will record the date & time when the version was made. This is not the last modification date & time of the file, nor is it the creation date & time of the file, it is the date & time when the version was created. SyncBackPro will take this versioned date & time into account when deleting out-dated versioned files from the $SBV$ folder.
Please read the Help file for more details. With Copy/Delete > Versioning setting page opened, press F1 to open the contextual help for more details
ozgurerdogan
Knowledgeable
Knowledgeable
Sorry for opening this thread again. But how can I delete a file from FTP if file / folder does not exit in source immediately? (I already enabled versioning)
I think you are asking (with edited phrasing / corrected typo)
...how can I [immediately] delete a file from FTP [destination] if file does not exist in source?
Set the option on Decisions-Files settings page, 3rd group ('File is in the destination but not the source') to
  • Delete file from destination if it hasn't been modified within the last [0] Days
This will normally delete such an orphan file immediately (the 0 argument tells the profile to disregard the LastModified stamp). However, if you have Versioning set up on the Destination, this means the orphan file will be Versioned immediately (moving it to the Version repository) instead of being deleted. How long it is retained as a Version thereafter will depend on your Versioning settings/rules.
