Have recently updated to V7.6.45.0 I discovered that all my email backups were doing the full slow scan as opposed to the normal fast scan, I downgraded to V7.6.36.0 (which I had downloaded but never got around to installing) and the same thing happened, I then downgraded to V7.6.8.0 which fixed the problem.
This is a important issue for me a slow scan takes 10's of minutes and is very likely to fail.
Andrew.
Fast email backup broken with V7.6.45.0 & V7.6.36.0
- Experienced
Re: Fast email backup broken with V7.6.45.0 & V7.6.36.0
Please submit support zip of the profile in-question with V7.6.45.0 and V7.6.8.0 for further investigation. Full instructions to create and submit a support zip are given here:
- Experienced
It may be sometime before I can reinstall V7.6.45.0 to reproduce the problem and produce the support zip file.
I suspect that the problem may be caused if you force a rescan which then gets stuck on even after a successful full scan.
Andrew.
Andrew.
- Experienced
This is fixed in V7.6.64.0.
Andrew.
Andrew.
