File name change after backup
dlohnier
Post by dlohnier »
i need to copya single File (a SQL Server Backup File) to the NAS for Backup the daily SQL Database.
I did not find an option to change the filename before or after such a backup (copy) in a task.
Any solution for this?
Regards, Reinhold
Re: File name change after backup
Sorry, there is no option in SyncBack to rename a Source/Destination file before or after the backup. However, if a file is renamed on one side, then it’s possible to rename the same file on the opposite side using “Detect file renames on left/right" of a Intelligent Synchronization profile.
Please read this forum post for more details:
viewtopic.php?t=12189&p=46765#p46765
