Are shared settings (such as email settings) included in the export when I export a profile that is using shared settings? And, if so, would the shared settings in the exported profile be 'restored' as shared settings if I import the profile on another computer running SyncBackPro?
Or is there another way to 'copy' shared settings to another computer?
Thanks in advance.
Shared settings question
Re: Shared settings question
Yes, when you export a profile (select the profile > right click > choose ‘Export Profile’ from pop-up menu), SyncBack exports profile files, shared settings (database files if any) into a single .SPS file, so that you can easily import all the related profile files (including shared settings) into SyncBackPro on another computer.
