New to SyncBack and so far very impressed.
I'm hoping someone can tell me if what I'm trying to achieve is possible.
In "File Decisions" I have it to copy from Left to Right if file does not exist on Right
If it does exist on Right then it should prompt me.
What I'm hoping to achieve is the "Differences" window will not show if the file does not exist on Right, at the moment the "Differences" does show even though I have not asked to be prompted. It just has the option Copy to Right pre selected.
Is it possible to get it to only show when a prompt is needed not a straight copy?
Newbie Question - Prompt / Differences
Re: Newbie Question - Prompt / Differences
You can enable the option “Skip the Differences screen when this profile is run” under:
Modify > Expert > Compare Options settings page
to stop the Difference Window from displaying when a profile is run attended (i.e. right click on the profile > select ‘Run’ from pop-up menu).
However, a File Collision Window will be displayed when SyncBack needs to prompt the user for a decision (so that the user can select the relevant action to perform on that specific file from the File collision window).
Note that for unattended profile runs (e.g. when run from the Windows Task Scheduler or if a profile is run in the background) the Difference Window or File collision window will not be displayed (and the file that requires decision will be skipped).
Exactly what I was after
