Syncbackpro runs twice?
machasm
Post by machasm »
I am using syncbakpro to backup files (each file is 16GB in size) from my Amazon Cloud computing to an Amazon Cloud drive.
When the backup is triggered manually the file appears to copy over at maximum speed. Once it gets to the end however, there is a pause and then the file appears to get retransmitted at a slower speed. After this transmission I am told that the file had been transmitted succesfully.
Is this normal behaviour?
There are no errors or anything untoward it just appears odd?
Also since this is being run from an Amazon cloud computer, bandwith is at a premium and I dont want every file to be retransmitted if it was succesful to start with!
This is running on windows 2012 server.
machasm
Re: Syncbackpro runs twice?
Post by machasm »
On further investigation I am beginning to wonder if the first attempt fails (for whatever reason) and then SBPro tries again?
If that were the case, would it not say so in the log?
Please submit a support zip with debug logs (of the profile in-question) for further investigation. Full instructions to create and submit a support zip are given here:
