Getting the following error when trying to Sync to AWS S3 in EC-Central-1
Failed to scan files: Cloud error 400: HTTP/1.1 400 Bad Request - The authorization mechanism you have provided is not supported. Please use AWS4-HMAC-SHA256. (InvalidRequest) (Amazon S3)
Any help would be appreciated.
Cheers
Si
SyncBackupPro 7.6 - AWS S3 Not Working
Re: SyncBackupPro 7.6 - AWS S3 Not Working
Apparently that region is using the new signature signing method so you need to go to your profile settings and then under Expert -> Cloud -> Advanced enable the option "Use newer Amazon S3 security".
