Random conflicts every time I run a scan :(
HZD8
Post by HZD8 »
Currently I'm testing the trial version of SyncBackPro.
My goal is that some selected folders on my pc are compressed, encrypted and sent on my Google Drive space. I want that on Google Drive is always present an updated "clone" of the folders on my PC. If I modify something on my PC modification must propagate to Google Drive, but if I modify something on Google Drive the change should be canceled because it is not even present on my PC.
So I created a mirror between my "source" (the folders on my PC) and "destination" (my Google Drive), I started the task and I created the "clone" on Google Drive.
The problem is that, as soon as I run my profile, the program, ramdomly, highlights some MB of "conflicts". Even if I do not touch anything on every scan "conflicts" jump out... and for this reason the program re-executes the (useless) uploading of files that actually have not changed and are present on both the source and the destination.
Where am I doing wrong ?
Re: Random conflicts every time I run a scan :(
Please submit a support zip with debug logs and a screen shot of the Differences Window for further investigation. Full instructions to create and submit a support zip are given here:
Do not post (nor links to) Support Zips on this open forum
HZD8
Post by HZD8 »
Done.
Now waiting for help :)
HZD8
Post by HZD8 »
The support was very quick and accurate.
Anyway I think I'll try other solutions...
