restoring a backup
DavidSon20122013
restoring a backup
Post by DavidSon20122013 »
My HDD failed (data files like photos, ms word docs, ... .Not the windows partition) , so I replaced it with a replacement, formatted it and restored a backup using Syncback Pro. After restoring, I did a simulated run (i.e, backing up what was just restored to the backup drive) on the replaced hdd and I see many files needed to be copied. Why does it happen - these files should be identical ? how do I correct this ?
Re: restoring a backup
Please submit a support zip with debug logs of the simulated run for further investigation. Full instructions to create and submit a support zip are given here:
Do not post (nor links to) Support Zips on this open forum
