-) I want to create a backup that rotates between 2 folders A and B. When the backup is run it should recognize that last time e.g. folder A was the destination and now use B. Then A again next time. I wasn't successful when trying to use variables - date or alike did not accomplish this. Is there an easy way I simply didn't see? If not could you give me a hint where to start scripting - just 2-3 lines pseudocode
-) Also I have another question: When I create a profile, which uses fastbackup, is there a separate database created per profile? If I create another profile using fastbackup, will it create an additional database for it? I assume it works this way
Thx a lot
Best,
Andi
