I've been backing up some folders to a .zip file (1 for -all- files) and notice that the .zip file is 1. -updated- (keeping some files that were deleted from the source) rather than -replaced- and 2. the .zip file retains its old date, not 'todays date' of which a few files would have. I tried to search for this seemingly common problem but your search app keeps telling me I've entered 'too simple' of a query with 'zip' 'compress' etc.
Is there a setting somewhere I'm missing that can delete the .zip file before the backup or must I create a .bat file and run it before the backup?
Ward
Backups to .zip files
Re: Backups to .zip files
Just noticed cause of #2 as windows explorer in my new PC was showing 'Date' instead of 'Date modified' and I never noticed!
W
W
Please submit a support zip with debug logs for investigation. Full instructions to create and submit a support zip are given here:
