Ignore Folders by Modified Date
JoshuaAce
Post by JoshuaAce »
I have a profile configured to monitor a folder [Source] for changes. When triggered it copies any new files that have been modified within the last 15 minutes out of the [Source] directory to a [Target] directory . The [Target] directory is a temporary repository for these files and gets emptied frequently by manual processes.
The [Source] directory needs to stay pristine, the ONLY changes it experiences is the addition of new folders and files.
The issue is, the profile copies over the entire directory structure from [Source], which results in thousands of empty folders each time the profile runs. It does successfully copy the files that have been modified within the configured 15 minutes :
Compare Options > Date & Time | Ignore files that have not been modified within the last 15 minutes
Any assistance will be greatly appreciated.
JoshuaAce
Re: Ignore Folders by Modified Date
Post by JoshuaAce »
I may have figured this out.
Decisions - Files > Folders What to do if a directory exists on [SOURCE] but not on [TARGET] = Do nothing
I had this set to Automatic
I was under the impression that by selecting Do nothing, new files nested in directories would be ignore. That does not seem to be the case as my test was successful when set to Do nothing.
