I found a similar question but no answers. The first run of a fast-backup works fine, but subsequent runs show a success but nothing happens. Doing a simulated (subsequent) run immediately give the pop-up titled "Information" "Profile: <profile name> No differences were found." This pop-up window shows up even before the progress bar in the main window starts animating. Looking below the pop-up at the main window, it shows in green text above the progress bar the number of files it should have copied.
I get this error when moving files from one folder to another on a network drive, either using a UNC path or a mounted drive letter. However, I don't get these errors when moving files on a local drive. Another profile successfully copies files from an FTP source to the same network drive, so it doesn't appear that permissions are the issue. This problem occurred in version 6 and now in the latest version 7.6.64.0 of SyncBackPro installed on Windows Server 2008 R2.
No differences found for fast backup
Re: No differences found for fast backup
Please submit a support zip with debug logs and the screen shot showing the progress bar for further investigation. Full instructions to create and submit a support zip are given here:
