Hi, I created a profile to backup local files from PC to Amazon Drive. I started it and while it was running I paused it, then stopped it, then attempted to exit SyncBack. It kept saying there was a profile running and asked to wait. The name of the profile changed and now has "corrupt" at the end.
I clicked wait a few times then finally gave up and just selected to exit.
After restarting SyncBack my profile is no longer there. It now has 2 profiles that say "imported" at the end but those are not mine and I have no idea where they came from.
Any ideas what happened, or what I should do differently next time to prevent this nonsense from happening again?
profile "corrupt" and no longer exists after restarting SyncBack
Re: profile "corrupt" and no longer exists after restarting SyncBack
As Amazon Drive profile was running in the background, I guess ‘force exit’ action might have corrupted your profiles and caused this problem. Therefore, in the future if you want to stop a running profile, I would suggest you to wait until the existing connection is closed and the profile is aborted.
In addition, if you are not using the latest version of SyncBackPro, I would suggest upgrading to latest version as we have recently fixed issues with profile abortion. You can download and install the latest version from the link below:
I am running the latest version 7.6.64.0
It just happened again. I just reinstalled SyncBack Pro. Created my profile. Started running. Selected everything in the list. Accidentally double-clicked an item. So while SyncBack was in the process of spawning 60,000 instances of photo viewer, I ended task on it in task manager. When I relaunched SyncBack, again, there are no profiles.
I'm guessing it doesn't save the profiles until the app is exited properly? Regardless, its extremely annoying.
