That the reply we are now getting from Office 365. It was working for months prior...
If I change it from SMTP to MS Exch Web Srv, I get the following: 403 Forbidden.
The result column shows error: 0x0000274c
So obviously your program is able to communicate through our firewall as these are replies from Office 365's system.
We are on version 7.6.64.0
Help!?
503 5.5.2 Send helo first
Re: 503 5.5.2 Send helo first
I found another thread on the forum that says to use the Advanced tab and set the port and local computer name. The information is not complete, so here is question about that thread: do I need to complete any of the other fields on that tab to make is work properly because now that I have set those two fields (port and local computer name), when I use the Test Email Setting, Syncbackpro hangs!!!
The 'Test Email Setting' window pops up and stays blank. I let is set for over ten minutes and nothing. I have to use the abort button and when I do SyncbackPro stops responding. I have to use task manager to kill it.
Something is seriously broken!?!
Could you please submit a support ticket to [email protected] with your profile configuration and the screen shot of the log that is displayed when you click on "Test Email Settings" button for further investigation.
