Exclude files with "Offline" Attribute from being copied
rl57
Post by rl57 »
I'm trying to exclude files with the "O" (Offline) File Attribute from being copied from the Source to the Destination. Can SyncBackPro 7.6.64.0 (Windows 6.3.0) achieve this?
If so how?
In Robocopy this would be easy - we'd just use the /xa:O switch
Many thanks,
John
Re: Exclude files with "Offline" Attribute from being copied
Hi
Modify profile > Search (near foot of tree on left) > enter "offline" (without quotes) in text box > click top hit in results pane
This will switch you to the appropriate ('Compare Options' > 'Attributes') settings page, then just set the appropriate checkbox.
There is no CLI equivalent; you need to add the setting in your profile via the GUI
rl57
Post by rl57 »
cliffhanger wrote:Hi
@ Cliffhanger,
I thought SynBackPro had that option because I saw it referenced in another article, but couldn't find it. -
Your resolution worked.
Thanks so much!
John
