One question. If I have this structure...
FOLDER1
subfolder 1.1
subfolder 1.2
subfolder 1.3
subfolder 1.4
subfolder 1.xxx
In source path, I check FOLDER1, and in "File and folder selection", only I check 1.3 for example.
My question is, why when checking the differences, read all the folders (1.1, 1.2, 1.3, 1.xxx)? You should read only folder 1.3.
Why?
Scanning to cloud (GDrive)
Re: Scanning to cloud (GDrive)
Please disable the option "Retrieve a list of all the files and folders then filter" under:
Modify > Expert > Cloud > Advanced settings page
and retry the profile run to see if it helps to resolve the issue. You can refer to the contextual Help for more details about this option (press Help button with Cloud > Advanced page opened).
- Enthusiastic
It does not work. That is the actual configuration, but it reads the full top folder. Is there a way to force the scans with the actual filters?
Could you please submit a support zip (with debug logs) and a screen shot showing your file/folder selections for further investigation. Full instructions to create and submit a support zip are given here:
