A question about cloud syncing
LaryW
Knowledgeable
Knowledgeable
Post by LaryW »
I have an Amazon Drive unlimited account and decided to upload a folder of scanned photos. It went OK but for some reason there were 2 that weren't copied to Amazon. I ran the Intelligent Synchronization again and both were uploaded with no problems.
The two files and the error reported by SyncBack Pro were:
1. 327,388 bytes and the error reported Failed to copy from Scanned Photos : HTTP/1.1 500 Internal Server Error
2. 1,831,362 bytes and the error reported Failed to copy from Scanned Photos : HTTP/1.1 504 GATEWAY_TIMEOUT
The folder I was syncing has 437 similarly sized photo totally about 488mb and although there were errors the sync continued on without other problems.
It appears to me these errors are Amazon actions that caused the error. But I'd be interested in know why they happened. Something related to uploading, Amazon throttling, SyncBack Pro communication error?
Since this was my first multiply file sync I'm trying to understand what's going on so to know what to expect in the future.
Re: A question about cloud syncing
HTTP/1.1 500 Internal Server Error or HTTP/1.1 504 GATEWAY_TIMEOUT
are returned from Amazon Drive server (not from SyncBackPro). Our program is just reporting the message back to the user. The possible reasons are: maybe there is temporary/internal problem on the server or the Amazon server might be under heavy load. When SyncBackPro receives this error, it will retry internally, but if it continues to receive the same error then it will give up and record an error in the log file.
If the problem occurs again in the future, I would suggest you to wait for some time and retry again to see if it helps? If the issue persists, then please submit a support zip for further investigation. Full instructions to create and submit a support zip are given here:
