AmazonDrive Errors: Failed to copy from Source : HTTP/1.1 400 Bad Request
rsn8887
Post by rsn8887 »
Using latest Syncback Pro 7 I am backing up to Amazon Drive. But I keep getting the following errors when backing up my ebooks folder. Here is an example:
5/16/2017 10:09:49 PM
\Books\Biology Books\Gray's Anatomy (ISO)\mdi-gray38.iso
Error: Failed to copy from Source : HTTP/1.1 400 Bad Request
The annoying thing is, Syncback Pro uploads the whole file FIRST, and THEN decides to throw that error, after waiting about 60 seconds. Needless to say this makes the backup unusably slow.
Re: AmazonDrive Errors: Failed to copy from Source : HTTP/1.1 400 Bad Request
Post by Kostas »
You'll have to generate a Support Zip with debug log for your profile and send it over to us for investigation.
Additionaly, can you verify if the failed files have been actually uploaded fine to Amazon Drive (via the Amazon Drive web UI)? Sometimes it's possible that an upload may say it failed but the file made it fine to the storage.
rsn8887
Post by rsn8887 »
Some of the files that generated errors are there on Amazon Drive, but most of them are not, I am now getting hundreds of errors, but not every file gives an error.
I will submit a support ticket.
rsn8887
Post by rsn8887 »
I submitted a support ticket the log file is called "K to Cloud.zip".
Here are two excerpts from the log. First file gives an error but appears on Amazon Drive, second file gives an error and does NOT appear on Amazon Drive:
12:17:50 PM \Campbell - Biology\Campbell Biology 7th Edition.pdf
Sent 5/17/2017 12:17:50 PM: 00000 n
0144216405 00000 n
0144216959 00000 n
0144217484 00000 n
0144218850 00000 n
0144219614 00000 n
0144219947 00000 n
0144220284 00000 n
0144222168 00000 n
0144222805 00000 n
0144293923 00000 n
0144294290 00000 n
0144294765 00000 n
0144295108 00000 n
0144295587 00000 n
0144296020 00000 n
0144300595 00000 n
0144301303 00000 n
0144301784 00000 n
0144302821 00000 n
0144305177 00000 n
0144307028 00000 n
0144374509 00000 n
0144374951 00000 n
0144375538 0
Recv 5/17/2017 12:17:50 PM: HTTP/1.1 400 Bad Request
Content-Type: application/vnd.error+json
Date: Wed, 17 May 2017 17:16:26 GMT
Server: Amazon-Cloud-Drive
x-amzn-RequestId: 98a15ff7-4d23-4287-b3ea-9d9055e4708e
Content-Length: 39
Connection: keep-alive
{"message":"Cannot read from request."}
[E] ParseLastResponseError: {"message":"Cannot read from request."}
[E] ParseResponseError: Cannot read from request.,
[E] IsRateLimited: HTTP/1.1 400 Bad Request
[E] IsRateLimited - Exception = "HTTP/1.1 400 Bad Request" - ClassName = "EIdHTTPProtocolException"
[E] IsRateLimited - Error Message = "{"message":"Cannot read from request."}" - Error Code = "400"
[E] IsRateLimited: NO
12:33:37 PM \Gray's Anatomy (ISO)\mdi-gray38.iso Failed to copy from Source : HTTP/1.1 400 Bad Request
Sent 5/17/2017 12:33:35 PM: GET /drive/v1//nodes/-S3BBYVWRoSP7RUaIlefSQ/children?filters=name:mdi%5C-gray38.iso HTTP/1.1
Recv 5/17/2017 12:33:35 PM: HTTP/1.1 200 OK
Server: Server
Date: Wed, 17 May 2017 17:33:35 GMT
Content-Type: application/json
Content-Length: 21
x-amzn-RequestId: f444922a-3b26-11e7-9aae-130fb98a38e5
Cache-Control: no-store
Pragma: no-cache
Vary: User-Agent
{"data":[],"count":0}
[E] IsRateLimited - Error Message = "{"message":"Cannot complete upload"}" - Error Code = "400"
