For Google Drive uploads with large file sets it can take a LONG time to scan GV for files to compare against. So a couple of questions/ideas:
1. Is there a recommended method to improve the performance of GV scans? I'm running v8 beta.
2. I would like to see a complete scan do something like:
a) create a scan file that has a local cache/list of all GV files with date/time info. This cache would be used, optionally, to calculate which new local files should be uploaded. No validation of existing files would occur but files in the list would not be sent. Of course the risk here is any modifications to the GV files would not be accounted for locally.
b) the use of the cache would be set globally but overridden at the profile level if desired.
c) A setting for when a new "full scan" should take place which would replace the local cache could be set as a default global or per profile setting.
For some level of confidence a profile could do a "surface scan" that would scan a partial set of GV content for changes and alert the user of a potential issue.
