Hyper-v VM backup
simonbr
Hyper-v VM backup
Post by simonbr »
I have one VM in a Hyper-v that I would like to backup. I was wondering if Syncbackpro was a good solution for this? Id like to backup without having to shutdown the VM.
Re: Hyper-v VM backup
SyncBackPro can copy open/locked files, but it requires the Windows Volume Shadow-Copy Service (VSS) to be working on your PC, and that the pre-requisites for using VSS are met:
http://support.2brightsparks.com/knowle ... backse-pro
Therefore, if you want to backup VMWare files (e.g VHD, VHDX files) when VM is running, then you should install SyncBack on the same PC where those files are stored (one of the VSS requirement) and create profile/s to backup files from source to backup drive. You can also try enabling the setting "Copy all files in [Side] from the shadow volume (snapshot)" under:
Modify > Expert > Copy/Delete > Advanced settings page
which may help (or trigger) VSS-aware products to 'present a matching/coherent set of files'. Please read these forum post for additional details:
viewtopic.php?t=10940
viewtopic.php?t=9468
simonbr
Post by simonbr »
Thank you for the reply. I had seen those post but they are a little older so I wasn't sure if there was more current news.
I have 2 questions regarding this;
1. What is the difference between the "in source" and "in destination" option? I am assuming I want to select the in source.
2. Do i have to select this option for SyncBackPro to use the VSS copy when a file is open or is it automatic?
If the option “Copy all files in Source…” is enabled, then SyncBack will copy all files on the source drive (within the profile’s scope) from the windows shadow volume, and “Copy all files in Destination….” means it will copy the destination files from the shadow volume (which option to choose depends on the direction of copy (Source to Destination or Destination to Source) and the side that is on the local drive). Please read the help file for more details about this option, with Copy/Delete > Advanced settings page opened, press F1 to open the contextual help.
Do I have to select this option for SyncBackPro to use the VSS copy when a file is open or is it automatic?
SyncBackPro (by default) uses VSS to copy open/locked files (on the local drive when it detects such files). However, if you enable “Copy all files in Source/Destination...” options then a snapshot is taken of the drive, and all files on that 'side' are copied from the snapshot at exactly the same time.
