Email notification group
ohaldi
Post by ohaldi »
How can I get one Email notification on a group.
Someting like:
Log Report: Overview
Group Profile : Back Disk F
Group Start Time 27.05.2017 09:00:03
Username PC-ATEHO\otto_000
Computer Name PC-ATEHO
Profile Name Back Agent Result Failure
Profile Name Back Electronique Result Success
etc.
Many thanks in advance for any help.
Otto
Re: Email notification group
Hi, There's a Group-level log you can read manually, but emailing it somewhere is not supported. Emailing the log is only supported per-profile (that is, for individual profiles that are not a Group).
I think the main issue is that a Group log's current format embeds hyperlinks to the drive/UNC paths & file-names of the main page/s of the individual per-profile log/s it lists (also, the group-log of any higher- or lower-level group 'involved' - so you can 'drill up' as well as 'drill down'). I guess that's why no email facility has been added (as those hyperlinks are unlikely to work when clicked on anything but the machine running SB).
ohaldi
Post by ohaldi »
OK, many thanks for your information's
Best regards
Otto
