Folder scan filter for target?
- Knowledgeable
I want to copy two folder from source to target which is on ACD. Problem is, target has lots of folders and I do not want SB to scan those folders. So I want copy content from two folder of source to two folder on target without scanning other root folder. Is that possible without creating task for each folder?
- Experienced
Re: Folder scan filter for target?
If I understand you correctly, you want to copy the contents of two independent folders into ACD.
In Source, select only the folders you want to copy.
In Target, select the path where you want to copy the source.
That way it would only scan selected folders in source and it will compare it with target. The time for scanning process will depend on how much files contents the source folder and destination. In my case, for about 100k files takes about 10 minutes.
By the way, ACD seems to be working normally since yesterday. Has it got any better for you?
In addition, please un-tick the option "Retrieve a list of all the files and folders then filter" under:
Modify > Expert > Cloud > Advanced settings page
and re-run the profile. Please read the contextual Help for more details about this option. With Cloud > Advanced page opened, press F1 to open the contextual help.
