I have a couple of profiles that seem to successfully upload files to ACD (profile set as Mirror), but after the files are uploaded, SyncBackPro displays "Saving Results...", currently sitting at 5 hours. These profiles uploaded around 500 files/8GB total, none of the files that large, and completed it in just under an hour, but the saving results just sits there.
I have a 350Mbps down and 25Mbps up internet connection.
I'm fairly new to using SyncBackPro for sync with ACD, does anyone know what process is happening during this phase?
if i kill it, the files appear to be on Amazon, and if I rerun it again, SyncBackPro successfully notices no changes required, but hangs again on that saving results.
I have another profile that has far fewer files and completes fast.
Is this the sync database that is being stored on my local machine being updated? Or something on ACD? No log is generated either.
Thanks!
"Saving Results..." displays for hours when running some ACD profiles
Re: "Saving Results..." displays for hours when running some ACD profiles
You'll have to generate a Support Zip with debug log for your profile and send it over to us for investigation.
