To see if you are eligible for a free upgrade to V8 from V7, or need to purchase an upgrade, visit the following web page and enter your serial number. If you purchased a V7 serial number from 2BrightSparks in 2017 then upgrading is free (simply install V8 and use your existing V7 serial number):
