SyncBackPro V8.0.2.0 and V7.6.82.0 BETA
Post by mickyj »
We've uploaded a beta V8.0.2.0 and V7.6.82.0. For V8, the only change is to fix an uninstalling issue. The V7 beta also fixes this issue. If you've previously installed older versions of SyncBack, and then you uninstall, you may get multiple prompts about keeping your profiles. This beta release fixes this issue.
V8 Beta
https://www.2brightsparks.com/assets/so ... _Setup.exe (32-bit)
https://www.2brightsparks.com/assets/so ... _Setup.exe (64-bit)
V7 Beta
