how can I use Syncback to transfer the folder structure of the source (including drive specification) to the destination folder?
For example I have defined as source the folder "C:\folder 1\folder 2" and as destination the folder "D:\backup". The folder structure in the destination should look as follows: "D:\backup\C\folder 1\folder 2".
I hope you understand what i mean.
Kind regards
Dieter
Folder structure of the source to the destination
Re: Folder structure of the source to the destination
Sorry, its not supported in SyncBack.
- DocRD
- Enthusiastic
Hello Dieter,
you can write "C" manually in the destination path and set a filter for "folder 1":
Source: C:\
Filter: *\folder 1\*
Destination: D:\backup\C
The result should be: D:\backup\C\folder 1\folder 2
Lg Kai
Source: C:\
Lg Kai
