Limit Upload Size Dropbox/Google Drive
- Experienced
Is there a way to limit the size of the backup when using either Dropbox or Google Drive? I am using the free versions of both services and have 4 GB of space on Dropbox and 15 GB available on Google Drive. My storage/backup needs are limited (simple home use backups) but it would be convenient if I could set SyncBack Pro (V8) to limit (purge older versions) the backups to a specific size.
- Advanced
Re: Limit Upload Size Dropbox/Google Drive
I don't think so. Same as when a local disk is full.
You need to manage this on your end.
Create some specific folders that won't be used for anything huge, and you'll be fine.
There are some other options. I don't know about the free version, but the pro version at least has the option to ignore files of a certain size, or ignore files that have or haven't been modified for a certain time - from seconds all the way up to years.
You would find it under Compare Options and then File Size, or Date & Time.
- Advanced
Ah wait, i see you're using the free cloud services.
And this is the SBPro forum of course
so the above should be an option.
